hoffman parts
tim smith
Member Posts: 2,886
We have no problem getting parts for Hoffman/B&G here in Seattle via Rep. You should have a rep that can help you in your area. Tim
Hoffman Specialty conds/vacuum float switch?
Can't believe I'm having a hard time finding a Hoffman Specialty float switch for their own conds/vaccum system.
When on this new customer and was given the keys to the building ( meanings I'm married to the job?) and have this steam system buctherd by others, I'm trying to get the the system in working order and the switch rusted and stuck... Its the one that have flange connection, not the 2" screwed connection as you see on the conds pump only unit... Thanks for any input...0 -
PATRIOT SUPPLY
Call Patriot Supply on Long Island 516-249-3100. They are one of the best commercial supply houses around.0 -
