Looking for a PVC vented oil fired boiler
John_108
Member Posts: 21
We have a customer that wants an oiled fired boiler installed but is limited for head height and does not want us to use a power venter to vent the boiler. Can anyone recommend a direct vent pvc oil fired boiler.
I can hardly wait to get an answer to this one.0 -
The wait is over
Try Dornback two pipe PVC 90% plus E-mail rsmls@att.net
I have quoted a couple of them but no sales yet so no first hand experince.They might be worth a look, nothing ventured,right ?0 -
FCX
The FCX by Monitor is PVC vented.
Tim D.0 -
I hope Dornback's boiler is better than their furnaces were.
My Dad bought one for his home several years ago. Probably close to 20 years ago. Positive pressure over fire and around 900F net stack. Piece of junk.0 -
not pvc but..................
thier are a number of "direct" vent boilers out here.
They use a metal hose kit that connects to the the vent thru the wall of home, burner is what exhausts flue gases outside. Solaia by Boyertown is one of them,have sold a few with no problems at all.0 -
Boiler
Burnham LEDV boiler has stainless steel liner with no power vent0 -
It is a furnace not a bioler
I know the rep. in the Pittsburgh area, great fountin of knoledge. According to him they redsigned them from just a couple of years ago,they were a nightmare to service.
These people even got some grant monies from NORA for their research.0 -
Direct vent
Don't know what you need for btu's, but take a look at the 115 Buderus. It is not pvc vented though. EJW0 -
put in a Dornback about 15 yrs ago
oil fired pvc vent, cracked exchanger a couple of years after we installed it, always had sooting problems with the vent. Never put in another0 -
The Solaia
is actually a re-badged 3-pass Biasi. It's sold in the Baltimore area as a Columbia. Nice little boiler and well supported.
PVC Vented Boilers
Thanks to all for the info. I call Doranbeck and was told that they sell furnaces only, no boilers. I also was able to talk to Monitor abot the FCX and this may work for us. The problem is the boiler is in the middle of the basement with no chimney and low ceiling height. Again thanks for the info.0 -
Ultra Oil
Take a look at Weil Mclain's Ultra Oil. This can be direct vented up to 15ft.0 -
back away slowly
If I understand the scenario correctly, you have a person who is insisting on a boiler installed in the middle of his basement/crawlspace with no chimney and no power venter.
How far (if at all) will the flue gases travel horizontally via natural draft without condensing? If the vent pipe is pitched properly, which way will the corrosive liquid travel after it condenses?0 -
vented oil boiler
Check out the new Peerless Pinnacle oil 90%+ direct vent,We checked it out at the New Jersey Oil show. Nice unit.0 -
John
the current boiler is in the basement?
how about placing the new boiler in the garage and piping the heat to the existing boiler? that would increase your options. if you do not have a garage, a small three sided building, bolted up to your home, could house a boiler...
many condensing boilers are designed to drop the stack exhaust ,heat incoming air,heat Up the fluids,bring back the lowest water temps.....off the Bottom and back of a boiler. meaning, starting out with them off the ground might make it easier to work with when you go in for the maintenance that needs to periodically be preformed.0
- 167 Indoor-Air Quality
