Esp od duct systems
Eugene Silberstein 3
Member Posts: 1,380
Here is ACCA's link for Manual D
http://www.accaconference.com/Merchant2/merchant.mv?Screen=PROD&Store_Code=ACCOA&Product_Code=29-D
Esp on duct systems
Where can i get on detailed book on understanding static pressures.
Thanks
Invest in
Invest in ACCA's Manual D. You will not be sorry. They have everything you wanted to know and more about duct sizing static pressures etc.0 -
Even Don
Even Don over at Lowe's has a copy on his shelf...0 -
Being I'm even
Don now...I also have the friction chart from ACCA that helps you to understand how the air flows in a duct system.
Also a great book to have on one shelf as well.
- 86.8K THE MAIN WALL
- 56 Biomass
- 108 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 69 Pipe Deterioration
- 954 Plumbing
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
