HTP and parts?
gerry gill
gerry gill Member Posts: 3,081
please separate your thoughts with periods..use two..it is very hard to read your posts..especially the long ones..i really like reading your postings, but boy can they be a challenge to the eyeballs..why are we going thru so many outdoor sensors..thats what i want to know..
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=360&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
gwgillplumbingandheating.com
  • Chas_2
    Chas_2 Member Posts: 104
    HTP and parts
    Has anyone else had promblems getting fatory parts i know i have besides eating some outdoor sensors i have gotten the brush on a gasket for a 80 wall hung for the flue adpter ,i only contacted my supplier and HTP about 3 or so months ago and still nothing ,this is really pissing me off ,but i can't really blame them it seems every body promises the moon and give you there **** and that's not just manafactures after fixing a local FAP listed so called pro i really have lost faith it seems there alot of so called pro's that are just hoods and crooks and are all about the money just look at my loop seal post and realize that this is and was the work of some listed here i removed the company logo to save them the shame ,from a totally disillusioned clam ,it's seems there are alot who are not true mech or pro's but they found a marketing tool to stucker in some it least i can have a clear mind what about you guys how do you do it ,mobster plumbers sorry for the rant and what about HTP peace and good luckclammy
  • Couderay
    Couderay Member Posts: 314
    HTP Parts
    I've yet to have a problem with parts for my munchkin and always go to SG supply in Illinois, Just south of Chicago. You can pick em up or they ship them. their number is 708-371-8800 ask for Phil,John or Jerry in the hvac dept. Will be there tomorrow picking up a out door sensor and a rear firewall.
  • Or...
    As Master Gill has said, we ALL enjoy your work and your thoughts Clammy. Just slow down, and hit the ENTER key twice between thoughts.
    Like this.
    As for parts, haven't had any problem getting them here. Are you trying to get them through a wholesaler or distributor or from the factory direct?
    You are obviously frustrated.
    ME
  • Chas_2
    slow suppliers
    Got in touch with some one at htp and the parts are on the way .As for ODS going just 2 one installed about 3 years or so and one less then a year and one that's just started to act up just once older style about 2 years .I'm using shielded stranded wire and now i'll be tinning the ends some thing i used to always do in the past .The other issue was a production line gasket which is being sent to me hopefully as i write .I'm really hoping that when i do run into a issue that my suppliers will pull through or i'll just contact the local dist they seem to responed a little better peace and good luck clammy
