gas hot water baseboard heat..mynupstairs pipes do not get hot w
MacVane
Member Posts: 6
not enough info
1 zone or 2
1 zone or 2
no heat upstairs
i have gas hot water baseboard heat. when the heater is running the pipes upstairs do not get hot0 -
Probably...
Air bound.
Bleeding the upstair's may do the trick. There are a bunch of other possibilities, but start with that possibility first.
Is the second floor on it's own zone? (Separate thermostats)?
heat upstairs?
How many zones?
How many thermostats?
What is aquastat high limit setting?
Bleed air out of upstairs radiation.0 -
i bleed the entire system. the system is on one thernostat0 -
one thermostat0
- 167 Indoor-Air Quality
