Pressuretrol Settings
Steamhead (in transit)
Member Posts: 6,688
Main- 2, Diff- 1. If you can get them lower, try main- 1, Diff- 0.5 .
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=367&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
In an earlier post I had given my Honeywell Pressuretrol readings as:
Diff = 2
Main = 3
Readings are subtractive.
It was suggested that I crankdown the pressure.
I know I am at a disadvantage not having a Vaporstat, but where would you suggest I set the pressure with the equipment that I do have?
Thanks in advance for any guidance.
Mike
Settings
Steamhead, thanks for the reply.
Mike0
- 167 Indoor-Air Quality
