BOILER ROOM PICS
FRANK_24
Member Posts: 80
This location is the Glen Cove Housing complex located on Long Island. The three old HB Smith cast iron boilers went by way of the Demo mans hammers, and we installed three Unilux bent tube water tube boilers input around 2.5 mil each. DHW was a 400 gal. stone lined tank kept hot by a Lochinvar which was not disturbed. We installed the four 119 gal indirect heaters. After the boilers were removed, we temped out two indirects with hoses in a temp location. Then removed the stone puppy and installed the new indirects. No overnight loss of hot water for the tennants. The boilers were then rigged into the pit and we did our thing. Piping, electrical, breeching, insulation and painting. (all or nothing at all) Again, the lowest qualified bidder shows 'em who's the best. lol
Amazing transformation...
... the jumble of pipes, mechanical actuators, etc. is replaced with a easy-to-follow layout. A nice and clean insulation job also! Presumably you did this all in a day, following the Ron Jr. Mantra, right?
How are the boilers controlled/staged?0 -
The lowest qualified
bidder forgot to equip the guy with the chain-drive wallet with safety glasses and a hard hat. Do I see isolation valves above and below the low water cutoffs?There was an error rendering this rich post.
These boilers are controlled by a Heat Timer multi mod, and Heat Timers HWR. And there are isolation valves on both sides of the LWCOs.0 -
Isolation valves required by code....
Another "anomoly" of the code....0
- 167 Indoor-Air Quality
