Pennsylvania boiler code high limit question
Alan R. Mercurio_3
Alan R. Mercurio_3 Member Posts: 1,624
Bryan, Call R.E. Michel and let them know what you're looking for. if your local branch can't help you. You can call L&I They should be able to lead you to someone who can.
PA Department of Labor and Industry
Room 1700
7th and Forster Streets
Harrisburg, PA 17120
General Information - 717-787-5279
Your friend in the industry,<BR>Alan R. Mercurio
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=408&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
  • bryan_4
    bryan_4 Member Posts: 5
    PA high limit requirements
    Is anyone aware of an actual control that meets the high limit requirement of not being able to be set above 210 degrees? I know this has come up in the past, and i haven't been able to find a control WITHOUT the tabs(limits) to limit the settings. I.E. Honeywell L4000's etc. do not meet the requirement. Ref: Act 85, HLW-701.1 Thanks in advance
  • Cosmo_3
    Cosmo_3 Member Posts: 845
    I have the number
    I have had to replace a bunch of these on existing boilers getting re-inspected this year.
    Honeywell #L4006E1125 100-200F Manual Reset high limit.
    Re Michel, or any stocking Honeywell distributor should be able to get it for you.
    Cosmo
