Adding a wall radiator to a copper baseboard system
Al Letellier
Member Posts: 781
Sure there are. Flat panel rads are very popular and are made by several companies. Buderus and Runtal are two of them that make a quality products. Runtal has all sizes, shapes and configurations of flat panel rads.Check themout at www.runtalnorthamerica.com
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=248&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Radiator on a copper baseboard closed loop
Are there wall radiators that can be added to a closed looped copper baseboard system? I would like to add a bit of extra heat to a room that was not properly outfitted when built. The is no more room for additional baseboard but there is a small (30") wall I could mount a radiator on at the end of the heating circuit prior to the reeturn.0
- 87.7K THE MAIN WALL
- 129 Chimneys & Flues
- 122 Geothermal
- 79 Pipe Deterioration
- 396 Solar
- 17 Recall Announcements
