heat gain program
Eugene Silberstein 3
Member Posts: 1,380
Thanks for the link!
heat gain program
What is the best heat gain program available in terms of accuracy and ease of use? Thanks.0 -
Can't say if it is...
the best, but if you go to the "contractor log-in" section of www.fujitsugeneral.com thereis a free program for your use. username is "installer". password is "1ton12kbtu". Hope it is helpful. You can also open all specs, install, operation, service manuals for each model.0 -
As the guys here...
As the guys here on the Wall are well aware, I am a big fan of Manual J. It is definitely NOT the easiest to use, but, as an educator, my take on the situation is, that, if you can understand Manual J and where the information is coming from, there is no heat gain/heat loss method that you will not be able to work with.
I teach my students Manual J for this reason.0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
