How to bend 1\" Multi-Cor
clammy
Member Posts: 3,242
to bend it how about a imperal wheel type bender they are made for 1 and 1 1/4 copper tubing and as for a support bend just hit up a electrical supply house for a 1 1/4 pcv 90 bend i have used 1/2 and 3/4 pcv electrical 90,s for similar set up peace and good luck clammy
R.A. Calmbacher L.L.C. HVAC
NJ Master HVAC Lic.
Mahwah, NJ
Bending 1\" Multi-Cor
Have a job where I need to run several remote manifolds. Am going to use 1" Multi-Cor under the blue-board in the gravel and "pop-up" under the manifolds. How or with what tool, do I make a nice tight bend in 1"? Any experience in doing this, or tricks of the trade would be appreciated. Do they make a PVC bend support for this like they do the hePex? Thanks in advance.
Regards,
Rocky0 -
Try
a REMS Curvo for nice clean quick bends in 1" PAP. I'd guess any hand bender with a follower would work.
I have bent the 3/4" PAP with and electricians condiut bender.
hot rod
