Insulating a staple up with web truss
hot_rod
Member Posts: 27,475
fastened to the subfloor? If so it is all conduction transfer and spray foam against the plates works well. Depending on the foam and operating temperatures, of course.
hot rod
hot rod
Anyone with experiance
insulating a staple up with open web trusses??
How do you insulate between the bays in the web truss openings?
Bergy0 -
insulatiing open truss
Use craft faced insulation the proper thickness and width and install some strapping at the right spot along the webs for a staple ledge and just fill in with small pieces under the top web.
- 120 Geothermal
