Too many cycles?
bmac.to
Member Posts: 2
Hello,
We recently replaced an 80 year old gravity boiler with a brand new Viessmann Vitola with outdoor reset, etc. after much advice from this forum. Living with the old boiler, we got used to wide temperature swings and very few on/off cycles during the day. With the new system, we had 62 cycles during the last 24 hours (an avg outside temp of 2 degrees C) which seems like a lot.
Is this normal? When it gets colder, does the number of cycles go up? If its not normal, what could be wrong?
Thanks.
Thanks.
when the temp gets colder...
the boiler should roll like a top....and keep on rolling.0 -
Check thermostat
Is the thermostat old? Replace it with a energy star thermostat. It fixed my cycling.0 -
There really is no thermostat - the control on the boiler has an outdoor reset and it adjusts the water temperature based on that. The thermostat upstairs is only connected to the pump but I have the thermostat turned up so the pump is always on (which is an approach I have seen recommended on this forum).0 -
Teknet 4
Look at your boiler system controls. If you use tN4, you can directly control the number of cycles.
I attached a page from the data sheet on thermostats.0
- 167 Indoor-Air Quality
