My steam heating system will not stay on. Any suggestions?
Brad White
Brad White Member Posts: 2,399
Not enough information to go on by remote. Do NOT push that reset button again if you like your eyebrows.
Could be a number of things, few of which would be "do it yourself".
Igniters, draft, fuel filter... others will have far better suggestions, but I would rather you not undergo skin grafts.
"If you do not know the answer, say, "I do not know the answer", and you will be correct!"
-Ernie White, my Dad
  • Michelle_7
    Michelle_7 Member Posts: 1
    Steam heating system
    I have a steam heating system and it will not stay on. I press the reset button and it will go on momentarily and then shut off again. How can I get it to stay on???
  • burnerman_2
    burnerman_2 Member Posts: 297
    brads right
    a lot of times a person calls and says they hit the reset and it runs a minute and shuts off if it is not ignitighting u r asking 4 trouble when i was a greenie i took a coustomers word said they hit the reset once or twice i had a stuffed up nose and did not smell any oil when i singed my eyebrows and the boom it was awesome scared the h'''' out of me and her she will always call a tech and so should u royboy(by the way she was on the phpne yellin at her hubby who confessed to hitting it 5 or 6 times and the transformer was bad never would have lit)
