Triangle Tube Prestige Control Supplement
Kal Row
Member Posts: 1,520
as this control is the same Honeywell used by most of the modcon vendors - this software is avail from Weill McLain, and mostly, only the programmable defaults are different, you can put an am4 module on it or the cheap one from hbx controls and modulate it externally one of the reasons I like Lochinvar so much is, that they "dont" use this control!!!
I would like to obtain the Triangle Tube Prestige Control Supplement. This publication illustrates how to change the advanced settings of the boiler...like the temperature curve. The boiler installation book only shows how to do basicoperations. The Triangle website used to publish it, but not any more.
Does anyone have this? I called Triangle up and they will not give it to me.0 -
Try posting this on the main section of "The Wall." More people will see it there!0
- 117 Geothermal
