measuring boiler PH
Dan_29
Member Posts: 111
I went to the local pet store and picked up some fish aquariam ph test chemicals for my WMc Steam boiler. I add boiler water into a test tube with ph testing solution and match the color up to a test strip. My ph level is 7.5
Dan
Dan
test kits for measuring boiler PH??? HELP- Dan Holohan
I can not find any litmus paper or any other way of testing boiler PH, for under $2000, I should add. Yes there is lots of expensive equipment for this, but no litmus paper that I can find.
Does anyone have a lead on this for me. I would like to start having my techs do this on a regular basis.
I have tried pool supplies, but their kits don't go above 8.4 which is too low for boilers.
Also, Dan H., if you can forward me that article you wrote recently about the importance of measureing this, I would appreciate it. Now that I want to start implementing this, of course, I can't find it.
Respectfully,
Paul B. Shay
pshay@arealgoodplumber.com
LMP 1307
LMFS 654B
OUR MISSION: TO PROVIDE WORLD CLASS PLUMBING, HEATING, AND SPRINKLER SERVICE TO EACH AND EVERY CLIENT WE SERVE, FAR EXCEEDING THEIR HIGHEST EXPECTATIONS!
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"Since 1990, I have made steam systems quiet, comfortable, and efficient. We provide comfort while saving the planet.
NYC RETROFIT ACCELERATOR QUALIFIED SERVICE PROVIDER
A REAL GOOD PLUMBER, INC
NYC LMP: 1307
O:212-505-1837
M:917-939-05930 -
Litmus Paper
Indigo.com is where I go. If you were closer, I would gladly give you some, Paul. I have more than I need.
I bought them in all different ranges, both wide and narrow ranges to see more accurately. Sort of like having two pressure gauges with overlapping scales if that makes sense.
http://www.indigo.com/test-strips/gph-test-strips/ph-paper-5-9.html"If you do not know the answer, say, "I do not know the answer", and you will be correct!"
-Ernie White, my Dad0 -
litmus paper
If you have kids in High School, or some friends who do, then you might get a couple of strips/papers from the science department. Possible listed as a science project or at home homework question. The local pool supply company probably has water test kits that do PH/chlorine testing. If you are looking for between 7-8 PH, one of their cheap kits might do the trick0 -
Go to George Lanthier's website, firedragonent.com. He sells an electronic ph pen for $46 post-paid0 -
Utility Products makes a "No-Freeze" antifreeze test strips pack that test antifreeze protection level and PH. I'm sure it would work on plain water too. I picked them up at the loca l supply house.
Either that or you can pick up an inexpensive test kit like one would use for a hot tub. The local pool supply should have them.
PH is PH0 -
Hanna
Hanna is one of the finest testers I have ever used. Make sure to get one that is ATC. Automatic Temperature Compensated. 80 coins will get one.0 -
pH papers
look on the web too for "pHydron" brand pH test papers or clones thereof. Cole-Palmer, Sigma-Aldrich, VWR, Fischer Scientific, and others should have them, about $10-15 a roll IIRC. Something in the pH 6-10 range probably would be good.
Aquarium test kits or lawn/soil test kits are another option, but probably only read pH 6-8 or so. Litmus paper (Cole-Palmer, Sigma, etc.) will only turn color below about 4.5 (turns red) and above about 8.3 (turns blue), so you lack resolution in the slightly acidic to alkaline region, but some red & some blue litmus plus an aquarium or soil kit might do the job.0 -
Would a,
simple swimming pool test kit not work?
I use one all the time, about 6 bucks anywhere.
Add 4 drops, turns purple or blue, you know your around 9, or higher.
Dave0 -
I have the ph test pen sold at Firedragonent.com, and it works great. Very inexpensive, and pretty much unlimited use. If you do antifreeze, check out the refractometor as well. I had bought a different brand before he started selling them, and I paid roughly 3 times as much!
Scott0 -
I don't recall an article.
I know I talk about it in the seminar.
I've seen electronic testers online for about $30, Paul.Retired and loving it.0 -
Digital pH tester
Paul
Test strips are OK for the casual user. They will tell you that you are in the ballpark, but for a professional I would think you would want to be in the game not just in the ballpark. Purchase a digital ATC ph meter. Two very names are Oakton and Hanna. Also purchase some calibration fluid (7.0/7.1) for calibration of the unit.0 -
Got my pen at Graingers
Hanna about 80 bucks.
hot rodBob "hot rod" Rohr
Living the hydronic dream0
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
- 79 Pipe Deterioration
- 396 Solar
