Hydronic Piping/Wiring
Bjorn_2
Member Posts: 7
New install --calling on services department
Hydronic piping - primary secondary closely spaced tee
10 zone low temp devided up into (6)zone w/ (2) taco 1" mix valve, (4)zone w/1 pc 705 injection control,
1 zone dhw high temp zone 1 zone high temp hwc
controls
10 tekmar stats w/ floor sensors for low temp
1 honeywell 8900 module for ac and ventalation and humidifier
1 honeywell 8000 stat (handles ventalation,humidity,heat w/ hwc and ac
1 honeywell remote bulb for hwc in ventalation mode to temper air in winter
1 honeywell aquastat for indirect h20
qty 1- PC705
qty 2-sr506exp
qty 1 40va transformer for tekmar t-stats
PI199 boiler
santa fe ahu
system pump is wired to zc on master sr506
pc705 is plugged into master sr506
problem
1 amp fuse in master sr506 exp breaking intermittently
pc705 was originally plugged into slave sr506 but
was also blowing 1 amp fuse
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=435&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
controls
qty 1- PC705
qty 2-sr506exp
PI199 boiler
santa fe ahu
problem
What is
the problem, Bjorn? I am missing that.0 -
Are all the components on the same circuit, or breaker?Joe Mattiello
Taco Comfort Solutions0
- 120 Geothermal
