Help with RFH design
David Hawks
Member Posts: 2
What would you consider small? Total area of existing + addition will be roughly 1600 sq.ft.
Hadn't thought about the electric yet.
Thanks
Thanks
RFH
Greetings, 20 year remodeler here, attempting to venture into the world of RFH for a spec. remodel (flip) I'm doing in NC.
Existing is wood frame w/ accessable joists 40x32. Proposed addition is to be slab-on-grade 16x32.
Natural Gas available.
From my limited research, I like the thought of combining the RFH with DHW. One zone???
Air handler in attic w/AC ducted through ceiling.
$$$ dictates that this project be DIY.
My "friends" on Breaktime said that this was the place to get answers to all my questions, as well as ones I haven't even thought of yet.
Please tell me: am I even on the right track with my plans here?
Almost forgot, this technology has NOT come to this part of NC yet, so I'll be ordering EVERYTHING.
Thanks0 -
in my opinion...
RFH is not a inexpensive thing that can just be "flipped"...not the cheap thing...if done right. You suggecsted combing the radiant w/ the DHW...you still need to seperate the two by way of a Heat exchanger...open systems are NOT a good idea...if the area is small and the load light elecrtic radiant might be the better idea...kpc
- 50 Industry Classes
