Atmospheric + Nibco + RMB
don_52
don_52 Member Posts: 199
Leo,
Thanks for posting Leo, nice work, I meant to ask
you about those terminal blocks your using now and
on the last set you posted. They appear to be the
Euro, finger safe style, do you have a
MFG/Part#, I like em'.
db
  • Leo G_101
    Leo G_101 Member Posts: 87
    A simple system
    Boiler is a locally made Allied SuperHot steel boiler. The rest is self explanatory. :)
    Leo G
  • Timco
    Timco Member Posts: 3,040
    How do you like the taco mix block? seems pretty pricey, but if it does all it says it does, it's worth it...is it an air separator as well?
    Edit: Looks great, may I add...should I ask if there is glycol in that system and get this thread going??? :-)
    Tim
    Just a guy running some pipes.
