need help finding gasket
Ken_40
Member Posts: 1,310
Topog-E
Here's one link: https://2692772420.monstercommercesites.com/index.asp?PageAction=VIEWCATS&Category=116
You MUST grind out all scale - and Never seize the draw bolts to snug up the replacements. If the ring is too corroded, or the man-way lip, it can be repaired by an R-stamp certifed welder.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=504&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Just a gasket, but leaking pretty good. Any ideas on where to find a gasket?
TimJust a guy running some pipes.0 -
It looks like a standard manway gasket. Around here all the good supply houses have them as do larger boiler or tank companies.0 -
Is there a way to confirm this and order it through you or your supplier? No one here seems to know what I am looking for. (SLC, Utah)
Thanks, TimJust a guy running some pipes.0 -
Can you measure it and make a sketch to take to the supply dude?? If you tell the supply house that you need a "manway gasket" you should be able to get some help.
Kevin0 -
Here is one more link. Ditto on the preparation and repair methods.
http://www.boilersupplies.com/boilergasket/gasketindex.html
Kevin0 -
Is that tank used for domestic water or some other purpose?
Kevin0 -
domestic. I have left a couple messages regarding this gasket, and hope to hear back soon. If not, I will order it rush from the posted link at PPI...thanks a million, TimJust a guy running some pipes.0 -
gasket
go to state supply web site also McMaster-carr has them also shows how to measure them0 -
Tim!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Something you HAVE TO TRY!. It's called "The Right Stuff" and it's a gasket material in a can which we have used in everything from Pool pumps to Pump and flange gasket for boilers. Why I like It? you may ask,...It gets you out of a bind and can permanently replace those special gaskets that take 1 to 30 day's to get in the mail. I'm not saying it's the end all to be all, but I Love it and it works. Call Me at 716-5706667, and I'll fire off a tube to you. Remember I am the 1 who got you last fitting for you for something or other..
Peace
Mike T. Empire Mech. Co.0 -
Looks like a handhole gasket
Plumber Supply, Hajoca, and Standard Supply in Salt Lake have these on the shelf. At least they alway did
There use to be a little plumbing repair shop on 33rd south below Highland Drive that had all sorts of old tank gaskets.
M-1 Specalties out west SL a bit has those gaskets also. If you work on old stuff you need to check out M-1 They ship odd stuff all over the country. A very unique business. Been there for close to 40 years.
www.m-onespecialties.com/repair.aspdecades.
There are also a few gasket specfic supply shops in Salt Lake. I'd bet they would have or could build that gasket.
hot rodBob "hot rod" Rohr
George and the guys at M-one are good friends of mine. At Hajoca, it's Vern to talk to...a good friend as well. The shop on 33rd is England, I believe. Turns out, no one had a manway gasket on the shelf, but PPI sent out the right gasket next day for me. It went in flawlessly today and I looked like a plumbing / hydronic GOD for fixing this. The old gasket was crisp, hard, broken, split rubber, and the new one was perfect. The plumber they called first wanted to just crank it down, and I said, it's your building...I will not try that.
Thanks for all the advise!
- 87K THE MAIN WALL
- 115 Chimneys & Flues
- 107 Geothermal
- 983 Plumbing
- 389 Solar
