Corner Radiator Valves
Tony Conner_2
Member Posts: 443
... seen an installation that used valves like this? There's another style that was a straight through pattern.
No, but......
.....I've got a pending project where those valves might be just the ticket, due to some tight space!!
Are these valves still available?
Starch0 -
I Suspect Not...
... but you never know. The scan is from an old (1902) Crane catalogue. I've never even seen pictures of valves like this before, let alone the actual item.0 -
NUBEE TO STEAM
I've owned my house for 6 years. The steam system has never worked right, so for most of the last 5 years, I've burned wood. Finally bought a new Burnham Steam boiler. IN-5 with electric pilot. Works great. I just got Dan's Steam deal book packet. I've reading and learning.
Couple of questions.
I replaced ALL the radiator valves and main vent valves. The system0
- 86.7K THE MAIN WALL
- 56 Biomass
- 105 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 948 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
