One manifold, 2 pex sizes
Wayco Wayne_2
Member Posts: 2,479
would there be if I used one manifold but had 2 pex sizes? I'm doing a quik trak zone, and an overpour so sizes would be 5/16, and 1/2.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=255&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Wayne.
i have not done the multiple size pipe off a "Factory header for some reason....
not that it cant be done , buh ,hear me out....balancing the system would be the wrench in the works , to me. here is why, the head on the 5/16th is likely to be on the high side, the flow rate on the low side for the 1/2" .then if that was not enough to contend with, the heat loss from the two entirely different areas might be significant enough to further cluster the thinking.
i do not own one of the fancy balancing tools that Uponor makes, with that tool, and designing the thing to a 'T' i might give it a go,..buh that is one of my Takes on doing that.
i have made a header though that was 10 mm and 3/8th...buh thats as creative as i have gotten
off a LLH ,now that is an entirely Nother Laval...that i have done.0 -
adjust the loop lengths
and they would get the same flow. The design should indicate the gpm per loop. As long as the manifold is supplied with enough GPM the rest is just a balance trick.
hot rodBob "hot rod" Rohr
Wayne,
I did something like this in my own home.
The dinning room & living room has 3 Quik Trak loops and the kitchen has one multicore loop in a wetbed. The area is pretty much open to each room.
I decided to run the kitchen off of a monoflow type arrangement that feeds the Wirsbo manifold. Did this with two tees in the supply to the manifold with a ball valve between. Took a little adjusting but works fine.
Jamie
