Replacement nut and spud?
Patrick North
Member Posts: 84
Maybe I can buy just the spud and nut, or maybe they'll be compatible with the existing valve body?
Thanks,
Patrick
Thanks,
Patrick
replacement nut and spud?
So, in disconnecting a steam radiator to refinish, I broke the brass nut portion on the union built into the 1 1/2" valve. Then the spud/nipple whilst trying to remove it from the radiator. I'm assuming I can just buy these parts as replacements w/out replacing the entire valve, right? If so, can anyone tell me just what I should be asking for so as not to get the hairy eyeball at the plumbing supply counter?
Thanks,
Patrick0 -
they usu.
come as a set.....they also usually don't fit uniform either....kpc
So...
Replace the whole valve?
Ugh,
Patrick0 -
maybe...
give it a go....you might get lucky. kpc
You will probably
have to buy the whole valve but try just the the end you need first but if they do not mate up you will need to change the whole thing0 -
Gotcha.
Thanks, guys- starting to get nippy around here.
Patrick0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 48 Industry Classes
- 15 Recall Announcements
