Atmospheric + Nibco + RMB
don_52
Member Posts: 199
Leo,
Thanks for posting Leo, nice work, I meant to ask
you about those terminal blocks your using now and
on the last set you posted. They appear to be the
Euro, finger safe style, do you have a
MFG/Part#, I like em'.
db
db
A simple system
Boiler is a locally made Allied SuperHot steel boiler. The rest is self explanatory.
Leo G0 -
How do you like the taco mix block? seems pretty pricey, but if it does all it says it does, it's worth it...is it an air separator as well?
Edit: Looks great, may I add...should I ask if there is glycol in that system and get this thread going??? :-)
TimJust a guy running some pipes.0
- 110 Chimneys & Flues
- 978 Plumbing
- 387 Solar
- 17 Recall Announcements
