B&G CHECK-TROL FLANGES
EMC PLUMBING
Member Posts: 22
8- 007 ifc pumps not the flanges.have you ever used the check trol flanges. i glad you never had a problem with the pumps but i have had numerous problems with water flowing trough the ifc pumps and have spoken to many other plumbers who have had the same problem thats why i use the seperate flow check valve. wanted to know if anybody had experince with the b&g check trol isolation flanges and un wanted flow
thanks
eddie
thanks
eddie
ANYBODY EVER USES THESE FLANGES, IF SO DOES THE FLOW CHECK REALLY WORK OR IS IT JUST LIKE THE TACO 00F IFC PUMPS WHICH WICH DO NOT STOP FLOW AT ALL. I HAVE LEARNED THE HARD WAY WITH THE 007 IFC AND HAVE BEEN USING TACO FLOWCHECK VALVES AFTER MY PUMPS ON THE FEED SIDE OF HOT WATER SYSTEM. BUT I SEEN THESE CHECK-TROL FLANGES AND SEEM REALLY NICE AND COST EFFECTIVE AND SAVE LABOR BUT AM SCARED TO USE THEM IF THEY ARE NOT GOING TO WORK. I DONT NEED AN INDIRECT WATER HEATER GOING ON IN THE SUMMER AND HEAT RISING THROUGH THE OTHER ZONES OF BASE BOARD. JUST WANTED TO KNOW IF ANYBODY USED THEM AND IF THE WORKED THE WAY THEY SAY THANKS
EDDIE0 -
There's
8 of them on this job,I've used many more with zero problems
Look Close
Those are check-trol flanges
I do too
They're pretty much all I use. Zero problems.0 -
I am in love with check trol flamges,... So much so the wife is jealous
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"There was an error rendering this rich post.
The
only thing I don't like is they are not sold individually.
ok thanks guys appericate the advice i guess ill give them a shot. if i use the sweatones i guess i have to be care full not to get soilder in the check valve.
any body ever have a problem with theses, i hate call backs0
- 167 Indoor-Air Quality
