lochinvar solution
Paul Rohrs_4
Member Posts: 466
I used to sell quite a few of these. Solid package. Like all copper-fin's, proper flow to the HX is key. I would suggest a wye-strainer and flow-switch. Terminals are very handy, the flow-switch can be wired directly to the terminal pad.
It does come with a printed circuit board that has Outdoor-Reset capabilities. I really never used that feature but I would think it is a solid platform if you want to incorporate it.
You have probably heard me say this, but I think Lochinvar is a 5-star operation and they exude class. Their products follow suit.
The attached pic was a job Biggerstaff's did back in 04. We usually stub-out for a future indirect water-heater.
Regards,
PR
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=353&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Regards,
PR
Lochinvar Solution
Has anyone used this boiler . How did it perform .The job is baseboard and the customer is looking for efficiency.
Its two stage boiler and has set back and claims 84 1/2%
any input .0 -
I installed one last fall
on an old baseboard system. That two stage gas valve is a very nice feature.
hot rod
