radiant ceiling and floor
We have a two story home with electric baseboard heat now and would like to put in radiant heating on both floors. We have 2" x 8" floor joists for the second floor. Most of the lower level has existing sheetrock ceiling. I would like to install radiant ceiling for the lower level and radiant flooring for the upper floor. Has anyone installed tubing above the sheetrock, installed insulation and then installed tubing for the second floor in a 2" x 8" joist space?? Someone told me that if we did the radiant piping above the sheetrock, the sheetrock would deteriorate in a short period of time. We are planning on removing the existing flooring on the second floor to accomplish our piping. Each floor would be a separate zone. Anybody tried this or had any experience with radiant ceiling with existing sheetrock??
thanks.
