rad question...HW
Really not difficult to remove the tapping bushing. Lay the radiator on its side, use a cheater bar on the biggest wrench you have and have couple people stand on the rad. I've removed MANY in this way and have never broken the rad.
  • Timco
    Timco Member Posts: 3,040
    So my helper, with the best of intentions, cut past the threads on two rads while extracting the brass nipples. Just past. They are 3/4". The dogs just broke off and the brass crumbled when we cut off the nut & applied a wrench. I am not opppsed to glueing the new nipples (unions) in, but do I epoxy, then re-thread or just polyurethane glue them in or JB weld? Any advise appreciated. Do not want to even try the 11/2-3/4 bushing. Old rads.
    Tim
    Just a guy running some pipes.
  • Timco
    Is one of the tapping bushings going to be LH thread? I may have one from another rad. If not, then what? I should add that this rad is in a bedroom with all hardwood floors and a large bed. I would prefer to glue this in, but should be able to find enough room and a drop-cloth.
    Thanks,
    Tim
  • Every tapping bushing I've ever seen uses standard RH threads on the outside. The inside thread might be LH in very unusual circumstances--like when a union or valve tailpiece isn't screwed into it.
  • Modern black steel reducing bushings may not be decorative like some of the originals, but they're close to the same overall length--if not exactly the same if you find them from the right supplier. Even if they're a little longer you shouldn't have any problem unless there's utterly no play in the piping.
  • I had the same problem
    a few weeks ago . We had to move a few rads around and couldn't get the brass union adapters out of the rads . They were 1/2 inch . We cut the threads flush with the bushing , then cut the sawzall blade down so it would fit in the hole . We cut 4 wedges into the remaining brass and punched them out with a screwdriver . Turned out to be the easiest part of the whole job .
