pe charts
Scroll down (or up) for charts!
  • ddenny
    ddenny Member Posts: 75
    pe charts
    I took professor silberstein's class on pressure enthalphy. I finished reading through most of the book and would like to start plotting some charts. does anyone know where to get some blank charts. never thought to ask that while I was at the class. thankyou
  • Techman
    Techman Member Posts: 2,143
    P.E. Charts
    Remember that each refrigerant has is own P.E. chart!
  • Eugene Silberstein 3
    Eugene Silberstein 3 Member Posts: 1,380
    Here you Go!
    Here are charts for R-134a, R-407c and R-410a. Be careful as the information for R-407c and R-410a contains metric pressure enthalpy charts as well!
    I do not have R-22 in a pdf, but I will e-mail it to you.
    Enjoy.
    You Have Mail
    You have mail Dennis.
  • Empire_2
    Empire_2 Member Posts: 2,340
    Hope this helps.
    I think the scanner should print clearly.
    Mike T.
  • Techman
    Scaners
    My scanner works fine,,,,,,,as long as I use a magnifying glass!!
    How is the Plotting Going?
    Keep us posted on how the plotting is going.
