Pex in heating system
Dave Belisle
Member Posts: 68
We use PEX all the time for baseboard zones.The copper drops through the floor and then we change to PEX.
With the new energy codes builders will insulate there floors and not there foundations . So we are putting the PEX up in the joist above there insulation so we don't have to insulate our pipes.
On indirects we come up to the joist with copper to keep it neat and the run with PEX.
Dave in NH
BP&H
Dave in NH
BP&H
can you use pex (veiga) on heating systems with out dropping the temp in the boiler. looking to install a indirect water heater and was tossing the idea around in doing it in pex. thanks0 -
Uponer
pex is rated at 200 degrees at 100 psi I think. Why not? WW
I have been trying FostaPex
with some of my mod con installs. It has a 20F at 80 psi listing. Available in straight 20 foot lengths also. Nice fitting system.
hot rod
At 20 F the glycol
content must be considered...
I'm sure the typo meant 200F NOT 20?0 -
I use fostapex exclusively for high temp heating. wirsbo for radiant. No problems.0
- 167 Indoor-Air Quality
