Insulation backing
Heatmeister_2
Member Posts: 88
Can I get some options? What have others successfully used considering time and material costs. I have heard that a rigid syro will squeak when the plenum space heats up.
what about
std. fiberglass...r-19
Foil Insulation under Ultra-Fin
Have used LowE Staple flange with great results.
Rob0 -
Can you please forward a link to the product
I am not sure what you are referring to.
Thanks0 -
Low E Website
Check this out. www.allgreeninc.com and check out the radiant heat link or go to http://www.low-e.com/
I can send you some pictures of an Ultra-Fin Job I am doing right now with this insulation.
Thanks,
Rob
- 167 Indoor-Air Quality
