Does anyone know if the comming Vitodens 100
Then why not use the Ultra 105 ?
has a 4.5 - 18 size range (i.e.; 16-60 Klb/hr).
I know that it does not have as sophisticated controls as the Vitoden 200.
A size range like the one above would match my application a lot better than the Vitoden 200 (6-24).
Perry0 -
The smaller size is going to be around 24kw, similar to the current Vitodens 200.
Nick0 -
Vitodens 100
I believe the turndown ratio for the Vitodens 100 is only 3 to 1. The small one is an 8-24. They make an 18kW version, but it doesn't modulate.
-Andrew0
- 167 Indoor-Air Quality
