Oil burner picks
Hi Dave, where do you get your hot water from?
do you have baseboard heat?
Three pass boilers are more efficent than the reg cast boilers, Having a inderect instead of a coil will save you money also, adding outdoor reset is even a better bet!
you add all these up, and watch your fuel bills go down..
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=386&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
  • dave Mac
    dave Mac Member Posts: 2
    Oil burner picks
    Looking to replace a oil burner in Downeast Maine.
    The choises are a eil-McLain WGO or a Buderus G115. Any ideas on which one is better?
    Thanks
    Dave
  • clammy
    clammy Member Posts: 3,242
    buderus g115
    For oil to me hands down buderus great boiler easy for cleaning and better insulation package then wiel and no combustion chamber fires into the cast comes with baffles to adjust stack temp .@ bolts and the front door opens with access to all flue passes and the combustion chamber great stuff ,if i where burning oil i would not even think about it every buderus g115 and g215 i have installed has and contiunes to to make my custemenrs happy .I personally can not say enough good things about there product plus 3 pass design and a sfor burners uses which one your installer is comfortable with installing and servicing in the future peace and good luck clammy
    R.A. Calmbacher L.L.C. HVAC
    NJ Master HVAC Lic.
    Mahwah, NJ
  • dave Mac
    I do have baseboard heat am thinking about a boilermate for my domestic.
  • David Sutton_6
    David Sutton_6 Member Posts: 1,079
    Buderus
    would be the best choice, go with the logamatic 2107 control with outdoor reset, you will realy enjoy the results..post some pictures afterwards. get more than one price and try find-a-pro here at the wall
