Does anyone know if the comming Vitodens 100
Then why not use the Ultra 105 ?
  • Perry_2
    Perry_2 Member Posts: 380
    has a 4.5 - 18 size range (i.e.; 16-60 Klb/hr).
    I know that it does not have as sophisticated controls as the Vitoden 200.
    A size range like the one above would match my application a lot better than the Vitoden 200 (6-24).
    Perry
  • Nick Ciasullo
    Nick Ciasullo Member Posts: 44
    The smaller size is going to be around 24kw, similar to the current Vitodens 200.
    Nick
  • ALH_4
    ALH_4 Member Posts: 1,790
    Vitodens 100
    I believe the turndown ratio for the Vitodens 100 is only 3 to 1. The small one is an 8-24. They make an 18kW version, but it doesn't modulate.
    -Andrew
