Prestige/Heatimer ??
Steve Ebels_3
Member Posts: 1,291
We just finished piping and wiring a pair of 175 Prestige boilers and a Heat timer Mini Mod multi boiler control late this afternoon.
I called Prestige regarding a couple issues and they handled my questions just fine. Problem is I ran into one more thing after I hung up and being after 5PM, I couldn't get back in touch with anyone. So I'm here picking brains again.
The issue is that I can't seem to find anyplace on the menu sequence that gets me into the heating curve. From the chart (page 12?) it appears that right after selecting the WWSD temp it should go into the area I'm looking for but I can't seem to find the right combination to get there. The boiler(s) presently run to whatever set point I select and then modulate there.
Got it
Thanks to Greg at TT! Sometimes when you stare at something to long the answer eludes you even though it's right under your nose.0
- 87.7K THE MAIN WALL
- 129 Chimneys & Flues
- 122 Geothermal
- 79 Pipe Deterioration
- 396 Solar
- 17 Recall Announcements
