Locate radiant piping?
Gordy
Member Posts: 9,546
You can buy a cheap 50.00 IR thermometer at radio shack.
Do you have electric , or hydronic radiant?
Either way like Weezbo says run it across the ceiling in both directions ( with the heat on) to get the just of pipe or wire orientation. The peak temp will be the center of the pipe or wire.
I have ceiling radiant in plaster, and this is how I found all my pipes. I was doing the same as you installing lighting boxes. The IR thermometer will come in handy for other uses also.
Gordy
Gordy
How can I know where radiant piping is in a drywall ceiling? I have an elaborate lighting system to install.0 -
best way is hire someone with the tools and instruments
to do so.
slightly more unreliable way may be to shut off all heat to the area for a day and at 4 a.m. get up turn the heat on only to that zone. have a pencil or marker in your hand note the room temps and ceiling temps and as the ceiling panel begins to show spots of heat on a IR gun put small circles on those spots as the day goes longer , take more readings ..do the same noting higher as well as lower temp areas on the ceiling...connect the dots from warmest temps to coldest... that would be probably pretty much the way it goes.0 -
Infrared Camera
Rent or hire a FLIR camera and you can spot the pipes easily. Sure it costs a few bucks, but then you can be sure that you will miss the pipes. What's the potential cost of NOT finding the pipes properly?0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 130 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 885 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
