The TRV's are worth more thnan that
Todd_13
Member Posts: 13
A full set and they look beautiful. http://tinyurl.com/nrznc
Too bad
It's pick up only. I have a client looking for a showpiece CI radiator for his Living Room.
Maybe Paul Poletts will check in.
Like Wayne said..the TRV's are worth more than the asking price !
Too bad they opted for air heat.Those are some beauties! Chris0 -
That's false advertising
that guy says the rads will work for steam or water. But look closely- no nipples across the top! They won't work with water. The fact that he tore them out for scorched air is more proof of his ignorance.
I didn't even notice that, I was dumbstruck that anyone would remove those from an old house. They don't even need stripping. I'm looking at another hanging radiator on there, but it doesn't have any of the mounting hardware. Is that available or is it make your own out of conduit hangar time?
In addition
those Danfoss valves with the vents on them are for one pipe steam only and will not work on two pipe steam or water. The operators are interchangeable .. but the valve body is not.
DWood0
- 167 Indoor-Air Quality
