parallel pumping instead of useing old large circulator i
t chace
Member Posts: 1
do you have any infomation on this way of replaceing an old b&g circ model 102214 with two small circs
Parallel Pump Application
If you can get me a little more information on the ITT we can offer two Stratos inlines where the two pumps can easily be piped and the electronics are wired together in parallel. This offers main/standby, if one can not keep up the second comes on automaticlly and 24 hour run time automatic alternation. Typically I suggest each pump be sized for 75% of the max flow demand.
Send me an E Mail and I will be happy to foreward you the information.
E Mail address is steve.thompson@wilo-na.com0
