Find the problem's with this install
tim smith
tim smith Member Posts: 2,886
Love the way the S&Rs will flow to those zones, have fun.
  • jim burke
    jim burke Member Posts: 26
    Repipe this job and why ?
    I went out to look at this install on sat. morning and this is what i stumbled into .I found to many problem's to list can you find some obvious one's.
    Will be doing a complete repipe & control design starting on monday .What were they thinking.
  • singh
    singh Member Posts: 866
    Well
    For one
    The return and supply seem to be on the same header with out P/S
    close spaced tees.
    He also has pump before tempering valve.
    The Fire extinguisher is too small.
    I do like that he used just about every single pump manufacturer in N/A : )
  • Plumdog_2
    Plumdog_2 Member Posts: 870
    for one thing
    they shoulda painted the plywood to class up the place a little. Can I get some of those pumps when yer done?
