C.I.American Standard baseboard?
Charlie from wmass
Member Posts: 4,425
I think you may be better off using new base ray or Governale though as shipping from here will make the base ray or governale less costly. If it is a matter of trying to keep it original let me know here and I will send my phone number to you.
cell # 413-841-6726
cell # 413-841-6726
Looking for 1 or 2,two ft. mid-sections of American Std. cast iron baseboard. It looks alot like Burnhams 9A, but won't match up. One of my suppliers said Am. Std. quit making it in 1968. Thanks for any info on this.0 -
I may have some
Please email me at cgandboys@yahoo.com. I know I have end caps and other trim. is the baseboard square or round on the top front edge? Also height and spacing c.c. on the spuds is needed. I am located in western mass.Cost is what you spend , value is what you get.
cell # 413-841-6726
Charlie; The spacing (center to center) on the nipples or spuds is 6 1/8 ". The top front edge is round. Each 2' mid-section has 4 oval slots on top where the air passes through. Thanks. HT0 -
Chalie, I'm not able to E-mail you. We're having a problem with the internet. I'm using a friends now. Can you give me more info on The Wall, or give me a phone # where I can reach you. Anyone else have any info on this Am. Std. baseboard? I may have to replace the entire 8 1/2' assembly with Burnham 9A (Baseray). Thank you. HT0
- 120 Geothermal
- 396 Solar
