painting
Irv
Member Posts: 95
Can latex paint be used on steam radiators?
If not what is best??
Oil's best...
From Hot Tech Topics above, in the Resources part of this website.
Painting Radiators
Does the color of a radiator matter?0 -
NEVER use latex paint on bare cast iron! Provided the existing coating is in good shape, latex can be used.
You can switch ONE TIME between oil and latex. Once you've put latex over oil you must continue to use latex.0 -
Hey Mike...
Do you still have the photo that goes with the post in Hot Tech Topics, above?
Noel0 -
I Latex is more flexable and resists chipping or flakeing and so if you prime with two coats of oil base primer you can use a latex finish, I did.0
- 50 Industry Classes
