snow melt sensor
hothead
Member Posts: 21
need a sensor for a small snow melt residential job. Could you direct me to choices of features costs and source? Thanks for your support,john
Hi John
Try Teckmar, they have many control set up's to suit your needs.
Mike T.0 -
You might Google snow melt controls. There are more options there.0 -
Snow Melt
tekmar has 20 plus years of snow melting experience. Consider using a tekmar automatic start snow melt sensor 090 and snow melt control 664, 665, or 667. The 664 offers the most options as it regulates the hyrdonic heating system using a mixing device and can stage two boilers. The 667 also operates a mixing device and one boiler. The 665 is the basic on/off unit that can operate electric snow melt or hydronic snow melt system using a condensing boiler.
tekmar also makes manual snow melt control called the 650 that is suitable car wash applications.
www.tekmarcontrols.com
Jay0
- 117 Geothermal
