thermostat
Empire_2
Member Posts: 2,340
Look at the literature and it should tell you. HW zone valves are nothing special...
Mike T.
Mike T.
thermostat
will a round ct87k honeywell thermostat -[all electronic with out mercury] work with honeywell zone vales using just 2 wires to thermostat.thank you mike,,,0 -
lit
www.customer.honeywell.com should let you access all lit avail, used to work for honeywell, and thats where we told people to look, hope it helps0 -
IF!
IF! you have a reeeeeeeeal old Honeywell ZV that is three wire - they are NOT compatible. At east not without a few "fixes" we could help with...
The odds of you having a three-wire (powered open and separately: powered closed) are about 1:100.0
- 87K THE MAIN WALL
- 115 Chimneys & Flues
- 107 Geothermal
- 983 Plumbing
- 389 Solar
