Ultimate boilers?
Mark Hunt
Member Posts: 4,908
they are the cheapest thing you can buy.
If that is what you want, you found Utopia.
Would I ever offer one??????????
No.
FWIW.
Mark H
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=238&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
No.
FWIW.
Mark H
Ultimate Boilers?
Are Ultimate boilers with a Becket burner good quality and a good buy for the buck?0 -
Ultimate Boilers
Dear Scott,
After reading the threads associated to your posting I felt compelled to write and let you know that the Ultimate brand of boiler is an excellent choice and explain why.
The Ultimate brand of oil fired boilers has been in the market place since the 1980¡¦s and is a premier leader with oil fired products in terms of quality and high efficiency with AFUE ratings as high as 87.6%. The list of benefits that Ultimate boilers have to offer is numerous but key benefits are as follows:
Installation Options ¡V Ultimate in Versatility
« In door installations
o Chimney Venting or Direct Vent through the side wall without an additional power venter!
X Direct venting solves many problems with homes with no chimney or those in need of repair.
o The Ultimate boiler is so versatile it can even be vented under ground!
« Multiple tankless Coil Options
o Ultimate boiler models are available that can employ 2 coils and higher flow 6 gpm tankless coils for domestic water heating applications.
o Ultimate boiler models are available for swimming pool heating applications.
« Out door Installations
o If there is a space constraint inside or a pool heating application the Ultimate boiler can be installed outdoors in a configuration that uses a specially designed stainless steel jacket.
« Burner options
o The Ultimate boiler offers the contactor choices. The Ultimate can be equipped with any of the following oil burners:
X Beckett
X Carlin
X Riello
The Ultimate boiler truly is an MVP in the hydronic market place with the options to solve most applications. And when combined with the long standing track record of this boiler brand, that has been meeting the high efficiency demands for well over two decades, Ultimate will end up being a very wise decision for your heating application.
Thank you for your interest our products and should you have any further questions regarding Ultimate boilers please contact me at 1-877-386-5475.
Sincerely,
ECR International
Mark Belcher
Appalachian Regional Sales Manager
U.S.A. Wholesale Distribution
