Direct Vent?
it is a good bet. I gave up on direct vents...try using a seperate intake hood like the areocowl set up ...I presume that you have plenty of space at the bottom of the vent?
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=323&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
  • Maynard
    Maynard Member Posts: 74
    Direct Vent?
    Went On A Buderus With A Riello BF burner. It Has A FT-4 termination kit. When The Vent Line For The Burner Fresh Air Is Hooked Up...Get #10 Smoke. Took Vent Line Out Of Riello And Rechecked With Burner Using Room Air...0 Smoke. Could It Be Caused by Cross Contamination At termination Kit?
  • Leo
    Leo Member Posts: 772
    I have my share
    I have my share of issues with this set up but I'll ask a dumb question. Is the inlet plugged? Unless this hasn't been right from the beginning there may be something else going on.
    Leo
  • Maynard
    Direct Vent
    1 Year old Boiler. Owner Claims She has Seen White Smoke Coming Out Of Exhaust Since Day 1? I Set Burner To Specs And this Is When I Found Problem With Fresh Air Vent.
