heat exchanger
Weezbo
Weezbo Member Posts: 6,231
check at Flat Plate on the internet ..it is a simple program.
Taco has a X block. it is like the RMB all in one package with a "Brain' .
it is a product of choice with me...on certain size systems within certain parameters....once again Flat-Plate is the simplest of programs to utilize...
  • MRRADIANT
    MRRADIANT Member Posts: 2
    I have a 10 zone system consisting of 7 zones radiant, 2 dhw tanks, and 1 hot water coil needing glycol to prevent freezing. I would like prefer not to mix glycol with the whole system for the sake of protecting one small zone from freezing, has anyone tried to isolate a zone with a heat exchanger for this purpose? This would allow me to cryotek one zone. Any thoughts, good or bad idea
    hot_rod Member Posts: 27,704
    Yes, remember you will need
    another expansion tank, circulator and iso flanges, relief valve, air purger, heat exchanger and maybe a low water cutoff in the event of a leak. Add up the cost difference, parts and labor you may be better off with glycol in the whole system.
    Johnstone Supply has a special on the Taco Mix Blocks, just under a grand. That would be a simple way to accomplish this and get reset control.
    hot rod
