Using chimney as chase for 95% vent?
hot_rod
hot_rod Member Posts: 26,604
if you have a straight shot. Make sure you have good support at top or bottom so the vent pipe weight is not on the boiler connections. Use the excat pipe that the manufacturer reccomends schedule 40PVC, not the cell core stuff.
Some brands require stainless vent pipe.
hot rod
  • Saggs
    Saggs Member Posts: 174
    I'm installing a 95% LP furnace in an old farmhouse w/ metal roofs. Snow fall and accumulation makes thru the sill venting almost impossible. I was thinking of using an empty interior chimney as a chase for the PVC exhaust and maybe the intake pipes. All of the chimeny is in heated space except for last 5ft. Do you think there may be a problem w/ freezing or frosting condensate inside pipe or too long a run? Total lenght is about 30ft. Temps in VT may get to -20 in winter.. Any thoughts? thx
  • Charles G.
    Charles G. Member Posts: 113
    VENT PIPE
    As always, follow the I&O manual for the unit. You may need to insulate the pipe in the chimney.
