baxi boilers
I've done a few, no significant problems. but like Bob said above, follow the prescribed installation techniques, also make sure you have the polarity on the line power correct ;) One I did with the <a href="http://www.wallhungboilers.com/prod_baxi_modulo.html">modulo</a> indirect, a very slick unit that attaches directly underneath the luna and basically puts the whole mechanical room into a 16" X 16" footprint, quite inexpensive too.
baxi luna boilers
Has anybody out there installed these??? and How are they???
Rick A0 -
Used many
Have used many,and is my boiler of choice. I have used both condensing and non condensing and have had zero issues. It's all about the piping and setup. Pay close attention to piping diagrams and you won't run into problems. Ask your supplier to assist you with piping diagrams. Good luck....0
- 167 Indoor-Air Quality
