Direct Vent?
kevin coppinger_4
Member Posts: 2,124
it is a good bet. I gave up on direct vents...try using a seperate intake hood like the areocowl set up ...I presume that you have plenty of space at the bottom of the vent?
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=323&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Direct Vent?
Went On A Buderus With A Riello BF burner. It Has A FT-4 termination kit. When The Vent Line For The Burner Fresh Air Is Hooked Up...Get #10 Smoke. Took Vent Line Out Of Riello And Rechecked With Burner Using Room Air...0 Smoke. Could It Be Caused by Cross Contamination At termination Kit?0 -
I have my share
I have my share of issues with this set up but I'll ask a dumb question. Is the inlet plugged? Unless this hasn't been right from the beginning there may be something else going on.
Leo0 -
Direct Vent
1 Year old Boiler. Owner Claims She has Seen White Smoke Coming Out Of Exhaust Since Day 1? I Set Burner To Specs And this Is When I Found Problem With Fresh Air Vent.0
- 167 Indoor-Air Quality
