WILO Stratus pumps Voltage
chris_93
Member Posts: 84
Thanks, I will check the curve on the eco.
rasputin231@yahoo.com
I'm interested in using a Wilo Stratos pump for a constant circ job w/ old rads and a modcon. Going to be using 1.25X 3-20 pump. Are all the pumps 230 volts? Electrican is giving me my price and needs to know??
Thanks,
Mike0 -
Voltage
All of the Stratos are 230v, single phase.
208v is no problem.
Hope this helps!
Mark H0 -
eco
are you sure you need a stratos? if the head/flow requirements are not too great the wilo eco is available now in either 115 or 230. you would be suprised at how low you can go with rads in a single family residential application.0 -
If you have any questions
contact me via e-mail.
Thanks for considering Wilo.
Mark H0
